My compositions are haunted by a red solid
Tim Bentley
on May 23, 2015 at 10:05:51 am
Hi all
I have a really strange issue, a small rectangular solid has been appearing intermittently in my compositions.
It is always in the same place and although it mainly appears when a comp is empty, it has cropped up a couple of times in the middle of a working composition.
I'm totally mystified, the above screenshot is from a COMPLETELY empty composition, no shy layers, nothing. Honest:
It did first appear around the same time that I had to unsubscribe and re-subscribe to creative cloud (I moved country, no other way to do it) but I can't see how they could be related.
I've been using AE for ages and I've never seen this before, it's more confusing than anything else - I managed to get rid of it in the first example by switching off the visibility of an audio pre-comp (?!), but I would love to hear from anyone who's had the same issue. It disappears at certain display zooms (100% usually, never 'fit display' though) but always appears in the final render.
Tim Bentley
Re: My compositions are haunted by a red solid
on May 23, 2015 at 10:19:07 am
Actually, thinking about it, the audio pre-comp is completely empty (apart from audio tracks) so the solid only seems to appear in empty compositions.
That being the case I guess it doesn't really matter, but I'm still very curious as to where it came from.
http://timbentley.info
Todd Kopriva
on May 23, 2015 at 3:34:58 pm
It's a bug in the cache system. You can flush the cache to clear it up (Edit > Purge > All Memory & Disk Cache). But, as you suggest, this shouldn't really be necessary since this bug just affects empty compositions.
After Effects product manager and curmudgeon
After Effects team blog
Tim Bentley
on May 23, 2015 at 3:43:43 pm
Oh, thanks - mystery solved!
