How to Fix Audio Spectrum Mask Issue?
Ryan Biankowski
on May 22, 2015 at 1:25:24 am
Hey everyone, I am having a tough time cracking this issue most likely due to being a novice editor. Any help is very much appreciated.
I have a layout that I use everyday. When I made the layout, I had it in 1280x720 not 1920x1080 - so when I wanted to skip the extra work and just scale things up, I scaled up my Spectrum Comp by to 130%. Although, now when I render my videos there seems to be a limited box about 300 pixels around the full comp size pertaining to the spectrum bars not being able to reach outside of those limits. I know it's some type of issue with the scale or mask settings. I'm looking to simply get rid of the mask and keep everything the same exact size. Can anyone provide help?
Let me know if I can provide anything else that would help.
Thank you,
Ryan
Walter Soyka
Re: How to Fix Audio Spectrum Mask Issue?
on May 22, 2015 at 12:52:28 pm
If you look at the same frame from both comps, I think you'll see that the spectrum is hitting the top edge of the comp. Just make the Spectrum comp taller in its composition settings.
Walter Soyka
