How make text patch onto the side of a building
David Honan
on May 20, 2015 at 5:05:03 pm
Hi from 15 degrees C very windy York Uk :-)
http://i216.photobucket.com/albums/cc53/zymurgy_bucket/office-to-let-on-win...
The above link shows an image of an office and some text. But in after effects I need the text to patch onto the windows so it follows the same plane if that makes sense.
I dont know the name of this technique so my search on Google was fruitless. So can anyone please give me some basic guidelines on how to make text or any object look like its a sticker on the pane of an office window.
Damn i'm struggling to explain this.... ok here is another way If i had a poster how could i make it look like its stuck to an angled window?
Thanks from I need to go home David :-(
Dave LaRonde
Re: How make text patch onto the side of a building
on May 20, 2015 at 5:27:16 pm
Mocha AE should be able to do a very good job of this... at least the tracking part. Getting it to look real is your part, which shouldn't be too tough.
Dave LaRonde
Promotion Producer
John Cuevas
on May 20, 2015 at 7:32:47 pm
If it's going to fit into one pane, I would precomp the text into a comp the same size as your final, then use the Distort > Corner Pin effect to place it into one pane.
Johnny Cuevas, Editor
Thinkck.com
"I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work."
---THOMAS EDISON on inventing the light bulb.
Derek Boettcher
on May 20, 2015 at 10:15:01 pm
You are basically looking for a form of motion tracking. Planar with mocha is probably the best bet. There are a lot of tutorials online for that or the other types.
Best,
Derek Boettcher
Creative Management
BTH Media Group
http://bthmedia.com
David Honan
on May 21, 2015 at 8:47:43 am
Thank you everyone for your advice, i will have a bash at this over the next too days and update :-)
