After Effects Best Render Settings
ryan maloney
on May 20, 2015 at 3:47:43 pm
I know this issue has been discussed many times over but I can't find a good thread for the best after effects settings for Macbook Pro 2015.
I'm having slow run speeds when designing, previewing, moving things around (at quarter resolution, fast draft view, 1280x720, not many pre-comps being used)
Can someone direct me to the right place on this forum or any good links to figure out the issue? My testing of different settings is turning up the same results so I'd see if anyone knows if I am missing something. Settings below
Thanks in advance for any info/links.
Ryan
Dave LaRonde
Re: After Effects Best Render Settings
on May 20, 2015 at 4:36:04 pm
Just turn off multiprocessing. It doesn't work in every instance, it can be buggy on rare occasions, and there aren't that many instances where it works flawlessly. That's something you can do right now. Wait for Adobe to get its act together on multiprocessing.
You might also have to update your version of AE... but since you didn't mention it -- right down to the very last decimal point of the version number -- we can't tell.
Dave LaRonde
Promotion Producer
ryan maloney
on May 20, 2015 at 5:42:25 pm
Thanks Dave.
Turning off Multiprocessing didn't do it, but updating After Effects seems to have solved it. Although it seems to get sluggish after a while, not as bad as before.
Appreciate the advice.
Ryan
