Recovering a template for a Block Transition
Zane Gould
on May 19, 2015 at 9:58:21 pm
I have been looking to create a digital transition, similar to the one being requested in this post:
https://forums.creativecow.net/thread/2/905093
User "Andra" supplied a solution. Unfortunately the Template AE file is in an old version of After Effects.
"Take a look at this and let me know if it's what you're looking for:
http://www.eurovoice.nl/cow/FractalLowerThirds.aep
Look at Wiping fractals 2.
Basically, I've used an adjustment layer set to Hard Light with a moving ramp. Placed that over the layer with the fractal noise. To finish things of, I added an adjustment layer with a threshold on it, to have the blocks switch on instead of fading in.
Wiping fractals 1 is something I made because I hadn't read your post properly the first time. I left it in 'cause I think it makes for an interesting effect none the less."
Is anyone able to recover this project and can update it for CC or CS6? Alternatively is anyone able to figure out a similar solve to this?
Thank you.
Dave LaRonde
Re: Recovering a template for a Block Transition
on May 19, 2015 at 10:06:54 pm
Do you know HOW old a version of AE? Any clue?
Dave LaRonde
Promotion Producer
Zane Gould
on May 19, 2015 at 10:10:26 pm
When I attempt to open it it says that it is "6.5 (Macintosh PPC)"
Dave LaRonde
on May 19, 2015 at 10:14:50 pm
If it's AE version 6.5, the most recent version that can open the project file would be AE CS 5.5, aka version 10.5. If you can save it as a CS 5.5 file, CC versions of AE can open it.
Dave LaRonde
Promotion Producer
Brian Charles
on May 20, 2015 at 1:43:56 am
Here you go.
8848_ltcs6.aep.zip
Zane Gould
on May 20, 2015 at 1:56:04 pm
This is extremely helpful, thank you!
