AE Script : Link Text.Source to Checkbox
Jonathon Lau
on May 19, 2015 at 1:56:13 am
Hey there,
I am making AE templates for a broadcaster which editors in Premiere can change quickly.
As Premiere allows users to adjust AE text layers via dynamic link, I was going to control my expressions via Text.Source inputs.
Sound idea, but I can't do it.
Question: How do you link a text source to turning on and off different checkboxes?
if the text is 1, Checkbox A will turn on
if Text is 2, Checkbox B will turn on
if Text is 3, Checkbox C will turn on
etc
I would really appreciate any help.
Thank you.
Darby Edelen
Re: AE Script : Link Text.Source to Checkbox
on May 19, 2015 at 9:29:43 am
The way you've described this it sounds like you want the text source to control a checkbox? I'd expect things to go the other way around generally.
At any rate, you'd need to check the value of the source text on each checkbox:
(thisComp.layer("MyText").source Text == "Hello!")
This should enable the checkbox if the MyText source text is Hello! Of course if the user enters hello? it wouldn't match.
I haven't checked the above code, there may be a small piece missing.
Darby Edelen
Jonathon Lau
on May 26, 2015 at 1:45:15 am
Thanks for taking time to type that up. Helped me a lot!!
Walter Soyka
on May 19, 2015 at 10:32:14 am
[Jonathon Lau] "As Premiere allows users to adjust AE text layers via dynamic link, I was going to control my expressions via Text.Source inputs. Sound idea, but I can't do it."
Have you seen my demo for this technique?
http://www.keenlive.com/renderbreak/2014/06/rigging-ae-comps-with-the-new-t...
I like to make it easier on the editor: I convert everything to lowercase for my testing, and check to see if the string contains the word I'm looking for rather than is strictly equal to it.
// get layer input and make it all lower case for easier testing
input = thisLayer.text.sourceText.toLowerCase();
// test to see if input contains "word"
if (input.indexOf("word") != -1) {
// what to do if "word" is found
} else {
// what to do if "word" is not found
(Also, this is an expression, not a script. Expressions are code that evaluate in the project as it is rendered and return a value into a property; scripts run outside of the render and can have manipulate the entire project.)
Walter Soyka
