Expression Control to work within a comp
Tiago Cav
on May 14, 2015 at 2:45:16 pm
I need a external controller, "Layer Control" to work with layers inside of different compositions, because I don't want to appear as options all the layers in the "Layer Control". Only specific layers for each "layer Control" are two effects in a "null", and each has a function. This "null" is the panel what I created.
Nathan Shinholt
Re: Expression Control to work within a comp
on May 14, 2015 at 2:59:00 pm
I think I understand what you're trying to do, but I'm not quite sure.
Lets say that Comp A has a bunch of layers in it, including Comp B. Above your timeline, you see the tab to open up the Comp B timeline. You can click that tab and drag it down to the bottom docking zone of the Comp A panel. Now you have two separate timeline windows open at once. From there, I believe you can parent specific layers or properties in Comp B to layers or properties in Comp A using the pick-whip. I hope that helps!
Tiago Cav
on May 14, 2015 at 5:19:52 pm
Amazing!
Thank you so much! Good idea, smart solution.
I did it, "Layer Control" is connected to an outer layer and inside comp that "Layer Control" is, now, have only layer that will be used to what I want. Work very well.
