Reflected lights of a (off screen) Disco ball... thoughts?
Adam Lewen
on May 13, 2015 at 9:19:13 pm
Hello!
I have a task where I need to create a number of different sequences of the reflection of a party-like atmosphere (Disco ball) on a flat wall (simple black solid)
It's not very complicated task but I don't wanna be repetitive and thought of asking here for different ideas of achieving
here are some refs of what I have in mind: (again, i aim only at the reflected light. not the ball itself)
http://tinyurl.com/knm5wdr
http://tinyurl.com/l47j4z5
http://tinyurl.com/l6be7yz
My method so far is;
Rotating an inverted Grid. Offsetting it's Position with time* and treating those rotated shapes with color\glow\glints (2 layer of different grids will sell the effect, a fractal will add some atmosphere)
But my post here is to bring up other ways. There are many ways to get such effect...
Thanks a bunch!
Adam!
John Cuevas
Re: Reflected lights of a (off screen) Disco ball... thoughts?
on May 14, 2015 at 1:01:41 pm
You might want to look at this very very old tutorial. Using Projection Layers to create a gobos and projector type effects
Completely different approach that might be worth checking out.
Johnny Cuevas, Editor
Thinkck.com
"I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work."
---THOMAS EDISON on inventing the light bulb.
