Reverse camera and null designation
Stephen Mendenhall
on May 12, 2015 at 6:13:33 pm
I'm having trouble wrapping my head around this one. Perhaps someone out there can help me.
- in AE, I have a camera rotating around a null. The null stays in the center of the screen and appears as though it is rotating. It was created this way because of a C4D export.
- I need the null to have the exact same rotation/movement, but independent of the animated camera, and viewed by a static camera.
- I thought I remembered a technique of parenting positions/anchor points and reversing them. Or something like that, but I just can't figure it out.
Any help would be greatly appreciated!
Walter Soyka
Re: Reverse camera and null designation
on May 13, 2015 at 1:18:41 am
[Stephen Mendenhall] "I need the null to have the exact same rotation/movement, but independent of the animated camera, and viewed by a static camera."
Maybe try an expression like this on the Orientation property of the null you need to rotate, referring to the moving camera:
lookAt(thisLayer.toWorld(thisLayer.anchorPoint), thisComp.layer("Camera 1").toWorld([0,0,0]));
Walter Soyka
Stephen Mendenhall
on May 13, 2015 at 2:52:06 pm
This is great. I thought it might use the toWorld expression.
What would be the best way to invert this? It works, but just rotating in the wrong direction.
Walter Soyka
on May 13, 2015 at 5:00:44 pm
Oh, goodness, I'm sorry -- I was thinking about this totally wrong.
Here's an expression I lifted some time ago from the inimitable Dan Ebberts. Make sure you set the first two lines to use your null and animated camera.
L = thisComp.layer("Null 1");
C = thisComp.layer("Camera 1");
u = C.fromWorldVec(L.toWorldVec([1,0,0]));
v = C.fromWorldVec(L.toWorldVec([0,1,0]));
w = C.fromWorldVec(L.toWorldVec([0,0,1]));
sinb = clamp(w[0],-1,1);
b = Math.asin(sinb);
cosb = Math.cos(b);
if (Math.abs(cosb) > .0005){
c = -Math.atan2(v[0],u[0]);
a = -Math.atan2(w[1],w[2]);
}else{
a = Math.atan2(u[1],v[1]);
c = 0;
xValue=Math.round(radiansToDegrees(a));
yValue=Math.round(radiansToDegrees(b));
zValue=Math.round(radiansToDegrees(c));
[(xValue),(yValue),(zValue)]
Walter Soyka
Stephen Mendenhall
on May 13, 2015 at 5:17:56 pm
Thank you so much for your help with this!
The rotation now works great, but the timing is a little off. The null starts late and finishes early. Would it be helpful if I provided the AE file?
8832_testanimation.aep.zip
Thanks again!
Walter Soyka
on May 13, 2015 at 5:49:33 pm
Let's back up a moment. What are you ultimately looking to accomplish?
Walter Soyka
Stephen Mendenhall
on May 13, 2015 at 6:06:21 pm
Thanks for your quick response!
Maybe I should have started with a little more detail. I apologize. In fact, after describing the needs of the project, you may have an entirely different and better approach.
-I have a certain animation (image sequence) rendered out from C4D. The camera and null honor an object in that sequence.
-The null is intended as a placeholder for text that will appear/animate around the object.
-This entire composition (which is 96fps) will be nested into another composition (set at 24fps). The reason for the frame rate difference is because I want to be able to time remap the sequence animation as needed without needing to blend frames.
-I want the null/text place holder to be a parent for an identical null within the 24fps comp. That way (the thought being) when I time remap the nested comp, the null in the new comp will honor the time remap. That way the text animation itself won't be time remapped. Just the relative position/rotation.
-In the past, I would just control all of the time ramping within C4D, but this project requires a little more fluidity, and I would like to control it in AE.
I hope this all made sense :)
Thanks.
Walter Soyka
on May 13, 2015 at 6:25:35 pm
There's a much easier way! We'll just sync up the keyframe values with the time-remapping.
1. Enable and keyframe Time Remapping on the 1_96fps layer in your 2_24fps_conversion comp.
2. Copy your Camera.2 and Null Data layers from 1_96fps into 2_24fps_conversion.
3. For each keyframed property on the camera, alt+click the stopwatch and enter the following expression:
valueAtTime(thisComp.layer("1_96fps").timeRemap)
4. Shift+parent your text animation to the copied Null Data layer inside 2_24fps_conversion.
Walter Soyka
Stephen Mendenhall
on May 13, 2015 at 6:48:17 pm
PERFECT!
Thank you so much!!
