Media Encoder not rendering with accurate frame rate
Matthew Wood
on May 12, 2015 at 4:43:27 pm
edit--- just realized that encoder is importing at the incorrect frame rate of 2997. How can I get it to interpret it correctly?
Hello. I have exported a jpeg sequence at 23.976fps. When I import it into encoder, it defaults it to "match source" and it has a grayed out frame rate of 2997. I uncheck the box, set it to 23.976 and render to h264 but the file is coming out at what is clearly a higher frame rate, most likely 29.97, judging by the difference over time.
I have rechecked the jpeg sequence by importing directly into AE and it lists it at the correct frame rate and is in sync the entire project.
I have done this plenty of time before, I am not sure what the issue is. Thanks for help
Walter Soyka
Re: Media Encoder not rendering with accurate frame rate
on May 12, 2015 at 4:58:26 pm
[Matthew Wood] "edit--- just realized that encoder is importing at the incorrect frame rate of 2997. How can I get it to interpret it correctly? "
"There is a new preference, Indeterminate Media Timebase, under Edit > Preferences > Media that you can use to set the frame rate for sources without an inherent time base, such as image sequences."
https://helpx.adobe.com/media-encoder/using/whats-new-2014.html#misc-update...
Walter Soyka
Matthew Wood
on May 12, 2015 at 8:09:18 pm
@Walter Soyka - Ha, yes, thank you. Exactly what I needed
Blood type O negative. I bleed zeros and ones
I dabble on the desktop
Shifted Leering, Any Perspective
Shifting Literally All Perceptions
SLAP
