Collapse transformed 3d layer doesn't cast shadow if any effects applied
zol ganbold
on May 12, 2015 at 11:33:01 am
Hello everyone,
if i apply any effects to the collapse transform checked 3d layer it loses the ability to cast shadow,
does anyone know any workaround?
Thank you
Todd Kopriva
Re: Collapse transformed 3d layer doesn't cast shadow if any effects applied
on May 12, 2015 at 4:15:27 pm
See this for a list of the things that break shadow casting and other 3D layer interactions:
https://helpx.adobe.com/after-effects/using/3d-layers.html#3d_layer_interac...
After Effects product manager and curmudgeon
After Effects team blog
zol ganbold
on Jun 26, 2015 at 11:24:56 am
couldn't find any helpful information out there, it says its impossible to cast shadow if you have applied any effect to 3d layers with collapsed transformation, what a helpless point!?
Cassius Marques
on Jun 29, 2015 at 1:59:54 pm
duplicate your composition (in the project pannel). Change those layer's cast shadow to "only". Place this new comp bellow the one you want effects applied. Thats one way to cheat it.
I usually link everything between those comps together via expressions so I don't need to keep changing things twice when/if needed.
