Need comp frame rates to stay different in final comp
Matthew Wood
on May 10, 2015 at 4:00:17 pm
Hello. I have done it before, I just cannot remember how. There are dancers at 24fps and music at 30. But they sync up exactly how I want them to when I play them at these frame rates, in different media player windows.
When either is adjusted to fit the other, it throws it all off.
How can I keep them at these rates and render together? I know I can just combine them with other software and it will be fine, but I have to have some fx react to the audio
I turned on the "preserve frame rate when nested" option on both comps but the audio comp still plays at the higher frame rate when I drop it into the main comp.... ????? Super frustrating
Blood type O negative. I bleed zeros and ones
I dabble on the desktop
Shifted Leering, Any Perspective
Shifting Literally All Perceptions
SLAP
Dave LaRonde
Re: Need comp frame rates to stay different in final comp
on May 10, 2015 at 4:09:56 pm
I'll assume the two comps are precisely the same duration. This shouldn't be an issue. Just nest the 30 comp with the audio inside the 24 comp with the video. No other adjustments should be necessary.
Now, if the audio comp suddenly gets shorter, I go back and double=- check those AE preferences. And if the audio is an mp3 or ANY kind of compressed audio, do yourself a favor and make a wav or aiff file of it, import it into AE, and use the Replace Footage command in a duplicated comp containing the audio.
AE occasionally gets goofy when dealing with compressed audio. It's never a good idea to use it.
Dave LaRonde
Promotion Producer
Matthew Wood
on May 10, 2015 at 4:21:21 pm
I had done what you suggest, initially, and it just wasn't working. It is an mp3, however, so I am going to attempt it with a wave, now, thanks
SLAP
Darby Edelen
on May 10, 2015 at 4:52:16 pm
Audio files don't have frames so there is no frame rate to speak of. Audio should play back at the same rate no matter what the frame rate of the composition is.
Darby Edelen
Matthew Wood
on May 10, 2015 at 4:36:47 pm
-- Ha, no, got it.. I put the 30 into the 24, initially. 24 into 30 as you suggested did it. You rock, man, Im stoked, thank you
SLAP
