Expression to check for keyframes
Pravin Chottera
on May 8, 2015 at 4:32:49 pm
I want to create an expression to control the particle count of particular based on the movement of a null object.
I was wondering if there was an expression to check for the existence of a keyframe. Basically, particular would look at the null to see if there was a position keyframe (the null has baked keyframes from C4D so there is a keyframe every frame) and only emit particles if there is a keyframe.
If there an a way to write an "if keyframe exists" expression?
Darby Edelen
Re: Expression to check for keyframes
on May 8, 2015 at 9:00:25 pm
You could use try/catch to access the first keyframe on the property. If there are no keyframes then it will fall back to the catch:
try{
test = position.key(0);
catch(err){
//No keyframes!
Darby Edelen
Darby Edelen
on May 8, 2015 at 9:02:39 pm
Ack, you know you've been away too long when you're over complicating expressions, this works too:
if(position.numKeys > 0){
//keyframes!
Darby Edelen
