Write-On effect, points are moving around
Matthieu Gras
on May 6, 2015 at 8:50:48 pm
I am using the Write-On effect to draw points from position keyframes of a null object. I set the stroke length to 3 seconds and the brush spacing to .01 seconds. The problem I have is that when I am using an other value than the standard value for the brush spacing, the points are moving around along the path. When I use .01 seconds for the brush spacing the points are standing still and this is what I want.
Michael Szalapski
Re: Write-On effect, points are moving around
on May 7, 2015 at 2:02:52 pm
[Matthieu Gras] "When I use .01 seconds for the brush spacing the points are standing still and this is what I want."
If it's doing what you want, I don't understand what your question is.
- The Great Szalam
Matthieu Gras
on May 7, 2015 at 4:33:51 pm
I want the points to stand still, but I also want to change the brush spacing. But when I change it to a value which is NOT the standard value, the points start to move along the path.
