Avoiding Particle Collisions with Camera (for Starfields)
Gern Blanstein
on May 4, 2015 at 7:12:38 am
When I create traveling starfields (stars moving toward the camera or away), it sometimes happens that a 'stray' particle will pass too closely to the camera (or to the viewport), which tends to ruin the effect in my opinion. This is particularly a problem with longer sequences.
I understand there aren't really any stray particles, but is there a trick for avoiding proximity with the camera or viewport?
Walter Soyka
Re: Avoiding Particle Collisions with Camera (for Starfields)
on May 4, 2015 at 11:52:33 am
[Gern Blanstein] "I understand there aren't really any stray particles, but is there a trick for avoiding proximity with the camera or viewport?"
Under Physics > Air > Spherical Field, you can create a spherical field which attracts or repels particles; putting this in front of the camera would create a "bubble" around which particles would wrap.
You could also use a layer emitter with a hole in it, sized just outside the rostrum, and use it to fire particles away from the camera into z-space, then time-reverse the entire animation.
Walter Soyka
Gern Blanstein
on May 4, 2015 at 12:56:52 pm
Two good ideas, Walter. Thank you!
Walter Soyka
on May 7, 2015 at 5:18:52 am
Here's a third idea, much simpler than the others. (You can decide if it's good): use Particular's Near Start Fade and Near Vanish parameters (under Visibility) to fade or cut stars out as they approach the camera.
Walter Soyka
