Multiple Keyframes from a motion path. How to time map through them with a slider?
Austin Wendenburg
on May 1, 2015 at 6:15:36 pm
Ive got 5 position keyframes forming a circle, of course if i set easing on the start and end ones I can only affect up until the 90 degree mark ( where the second keyframe comes in).
There must be an expression where I can link to a slider control where 0% is the first keyframe and 100% is the last keyframe?
Thanks in advance!
Walter Soyka
Re: Multiple Keyframes from a motion path. How to time map through them with a slider?
on May 1, 2015 at 8:29:09 pm
You could pre-compose your animation and adapt my solution from this other thread:
https://forums.creativecow.net/thread/2/1061354#1061377
Walter Soyka
Austin Wendenburg
on May 1, 2015 at 8:32:45 pm
That'l do it! Thanks for the help!
