Fit text into defined space
Matthew Beall
on Apr 29, 2015 at 5:37:03 pm
I am makings some disclaimers and would like the text to exactly fit in a defined space (a box) so that it is a block of text. Is there a way to do that in AE?
Dave LaRonde
Re: Fit text into defined space
on Apr 29, 2015 at 5:54:22 pm
I do it by eyeball.
First, I make a rectangle of the desired size & aspect ratio.
Then I make a text layer, center the text in the paragraph pane and srtart typing or pasting in text. I'll add line returns at the approximate ends of lines. It looks neater that way.
Then I just scale down the text until it fits in the confines of the rectangle. If I spend more than 5 minutes on it, something's wrong.
Dave LaRonde
Promotion Producer
Walter Soyka
on Apr 29, 2015 at 6:38:41 pm
Are you familiar with the difference between point text [link] and paragraph text [link] in Ae?
Walter Soyka
