Problems exporting with After Effects
Mike Hudson
on Apr 28, 2015 at 5:21:43 pm
I'm trying to export a sequence from After Effects, but when it's encoding, an object shows up that hasn't even been used in the project at all.
Here's what I mean:
This is what it looks like in the project (How the final product SHOULD look) http://i.imgur.com/g2i5PBG.jpg
This is the exact same frame while it's exporting. That photo that's showing up hasn't even been imported into the project, let alone my timeline, so I'm not sure why it's there. http://i.imgur.com/5wc5XL4.jpg
Does anyone have an explanation? Thanks!!
Dave LaRonde
Re: Problems exporting with After Effects
on Apr 28, 2015 at 6:09:48 pm
Without knowing specifics of your system, try purging EVERYTHING. All your caches, the works. Do a Purge All. See if it helps.
No joy? Transcode that mp4 to a quicktime movie in Photo JPEG, Animation or PNG codecs. Maybe that'll do the trick.
Dave LaRonde
Promotion Producer
Mike Hudson
on Apr 28, 2015 at 6:19:24 pm
Clearing my cache worked, not sure how I didn't think of it. Thank you so much!
Jon Doughtie
on Apr 28, 2015 at 6:10:00 pm
Have you cleared cache lately? If not, clear cache and see if the offending item disappears.
Mike Hudson
on Apr 28, 2015 at 6:20:01 pm
Thank you!
