How to prevent Audio Spectrum effect from clipping at layer's edge
Dave Mathews
on Apr 26, 2015 at 12:52:30 am
I created an ellipse mask around the object in the below image, and I set the Audio Spectrum effect to that mask. When the effect animates, you can see clipping occur where the object's layer ends. How can I make it so the effect goes past the edge or does not clip? Thanks in advance.
John Cuevas
Re: How to prevent Audio Spectrum effect from clipping at layer's edge
on Apr 27, 2015 at 2:54:31 pm
Just make a much larger solid
Johnny Cuevas, Editor
Thinkck.com
"I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work."
---THOMAS EDISON on inventing the light bulb.
Dave Mathews
on May 1, 2015 at 10:40:27 pm
Thank you, it took me too long to figure that out...
Roei Tzoref
on Aug 21, 2016 at 11:31:17 pm
you should set your mask to "None" and it will not be clipped. had to learn this obvious thing from a kid on Youtube :)
