Memory & Multiproccessing Configuration
PaMe Sepulveda
on Apr 24, 2015 at 10:05:56 pm
Hi All, I'm new in After Effects.
I would like your recomendations to set the configuration for the multiproccessing for my computer.
The specifications are:
Installed RAM: 61.03 GB Current RAM Usage: 1.02 GB Allowed RAM Usage: 55.03 GB
Process ID Application Name Min Needed Memory Max Usable Memory Max Allowed Memory Current Memory Current Priority
5124 After Effects 0.40 61.03 55.03 1.02 1 - High
I was testing this option but my render takes more time if this is disable. Is that possible? this option should be increase my render performace ?
I hope you could help me!
Thanks!!
Pame.
