Refraction for After Effects CC after Normality?
Mike Gottschalk
on Apr 24, 2015 at 1:11:38 am
hi—
I need to use 3D passes of a glass-like material to distort or refract layers in After Effects CC
I understand that the plug-in Normality was able to achieve this effect very well, but that it no longer functions for AE CC
Is there an alternate method available? I know that Nuke has iDistort, which takes a 3d normal pass and refracts underlying footage. And my understanding is that Normality had done something similar.
Maybe there is a functionality in AE CC that I am missing. Or maybe there is a way to recreate that refraction effect through a clever compositing structure.
I appreciate any ideas, and encourage Adobe to look into the Normality functionality for a future feature set.
Mike
Walter Soyka
Re: Refraction for After Effects CC after Normality?
on Apr 24, 2015 at 5:42:02 pm
Frischluft ZbornToy [link] can help you with refraction, given a normal pass.
Walter Soyka
Mike Gottschalk
on Apr 24, 2015 at 7:12:05 pm
Thanks, Walter!
I knew about Frischluft as a great depth of field option, but I hadn't known about its refraction capabilities
I will try it out
—Mike
Darby Edelen
on Apr 24, 2015 at 11:56:27 pm
Nuke's IDistort node is equivalent to After Effects' Displacement Map effect.
Darby Edelen
