Making shape layer rotate to follow a null's position
Tom Nichols
on Apr 23, 2015 at 10:45:51 pm
Hi
I need to use and expression to create an animation of a magnetic field attraction. So i have a series of small rectangle shape layers and would like them to follow a null around the screen always pointing at it.
I want the rectangles to rotate on there own anchor point towards the null.
I figured it would be something equivalent to a point of interest that i could attach to the null and therefore create the attraction.
Like this magnet style:
If I could have a couple of pointers that would be great.
Tom
Frank Feijen
Re: Making shape layer rotate to follow a null's position
on Apr 24, 2015 at 12:32:25 pm
Have a 'look at':
https://forums.creativecow.net/thread/227/10502
Tom Nichols
on Apr 25, 2015 at 4:00:53 am
Thanks Frank for that but it doesnt quite fit my needs.
This is my base equation:
Line = length(toWorld(anchorPoint), thisComp.layer("Null 1").transform.position);
delta = toWorld(anchorPoint) - thisComp.layer("Null 1").toWorld([0,0,0]);
radiansToDegrees(Math.atan2(delta[0],-delta[1]))
But i need it to react so that the further away it is from the X and Y axis the more accurate the direction of line is. And vice versa.
So i extended it to this:
YNull = length(toWorld(anchorPoint), thisComp.layer("Null 1").transform.yPosition);
XNull = length(toWorld(anchorPoint), thisComp.layer("Null 1").transform.xPosition);
radiansToDegrees(Math.atan2(delta[0],-delta[1]))*(Math.atan2(ease(YNull,740,850,3,1), ease(XNull,390,500,3,1)))
But now it will not follow my Null layer correctly. I will attach a picture below of both expressions results.
You may notice a grey opacity and that is where the lines should be to fit the design.
BASE EXPRESSION:
EXTENDED:
