Trim Path Angle
Heru Prasetyo
Trim Path Angle
on Apr 22, 2015 at 9:20:53 am
Is there a way to change the angle my trim path "grows" from? It seems as though the offset angle only allows me to change the direction around a circle? What I want is for this shape to "grow" from end to end, not around the circle it currently is.
The only way I can think of fixing this problem is by creating the shapes again from a single path and add a stroke, then keyframe the trim paths?
If i've explained this badly, i've provided some images to illustrate the problem further.
Roland R. Kahlenberg
Re: Trim Path Angle
on Apr 23, 2015 at 1:17:15 am
Trim Paths work better (creates more expected/intuitive results) with Stroke than Fills. So ... remove/disable Fill and enable Stroke and change the Stroke size to suit your needs.
- Roland
TypeGEMs - the Definitive Type Gizmo for AE
Intensive mocha & AE Training in Singapore and Other Dangerous Locations
Adobe After Effects CC ACE/ACI
Imagineer Systems (mocha) Certified Instructor
© 2018 All Rights Reserved
