 | Text getting cut off when rotating X and Y
on Apr 19, 2015 at 9:29:17 pm |
I'm trying to make this text (3d object) rotate on the X axis but pieces of it are getting cut off.
Any idea what might cause it?
 | Re: Text getting cut off when rotating X and Y on Apr 19, 2015 at 10:15:18 pm |
Try moving it forward on the Z axis. It's getting cut off because you have it intersecting with the layer beneath it.
Joe Bourke
Owner/Creative Director
Bourke Media
http://www.bourkemedia.com | Re: Text getting cut off when rotating X and Y on Apr 19, 2015 at 10:27:54 pm |
Not sure what you mean, but I've tried copying the layers onto a new composition and it doesn't seem to be conflicting with anything as of now.
 | Re: Text getting cut off when rotating X and Y on Apr 20, 2015 at 1:00:04 pm |
When they were in the original composition, your background layer(solid with a ramp) was in the same 3D space as your letters. Joseph was suggesting moving the background farther back along the Z axis so the it wouldn't cut off the letters. Use the custom view settings(under the comp window) and you will get a better idea of what is happening.
Johnny Cuevas, Editor
Thinkck.com
"I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work."
---THOMAS EDISON on inventing the light bulb.
