Rotoscoping
Ali raza qadir
Rotoscoping
on Apr 19, 2015 at 9:43:00 am
Hi guys,
I have a clip of a moving car which I rotoscoped. Now I want to rotoscope the environment of the same clip. Is there any way I can invert the rotoscoped part of the clip selecting the car to reverse it so taht only environment is rotoscoped now?
Ali
Tero Ahlfors
Re: Rotoscoping
on Apr 19, 2015 at 10:56:02 am
You can do this by using different mask modes like subtract. See more here: https://helpx.adobe.com/after-effects/using/alpha-channels-masks-mattes.htm...
John Cuevas
Re: Rotoscoping
on Apr 19, 2015 at 3:24:07 pm
Duplicate the clip and remove the rotoscope from the bottom clip, then set the bottom clips track matte to "alpha invert"
Johnny Cuevas, Editor
Thinkck.com
"I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work."
---THOMAS EDISON on inventing the light bulb.
Ali raza qadir
Re: Rotoscoping
on Apr 22, 2015 at 1:05:46 pm
Thank you very much John, it worked pretty well.
