wipe transition
Jony Conde
wipe transition
on Apr 19, 2015 at 3:45:06 am
Hello all I just wandering is some one there know how I can can do this in effect in after effects is like wipe transition thakns a lot
From 0:11 to 0:16
John Cuevas
Re: wipe transition
on Apr 19, 2015 at 12:08:16 pm
It looks like a split flip display. I've seen a few templates for doing it with text. Basically, those templates have created a split/flip for each letter number, which if you want to do it with images, you will have to create 1 for each image you would like to flip.
Here's a tutorial I came across, should help you get started.
Johnny Cuevas, Editor
Thinkck.com
"I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work."
---THOMAS EDISON on inventing the light bulb.
Jony Conde
Re: wipe transition
on Apr 19, 2015 at 10:50:12 pm
Hi John Thanks so much for replay this message? this can help me a lot
are you motion graphics designer?
John Cuevas
Re: wipe transition
on Apr 20, 2015 at 12:51:50 pm
I'm primarily an editor, but I've become the go to motion graphics guy in our production house.
Thinkck.com
