Keyframing effects in AE on imported Premiere Pro sequences
Dre Mark
on Apr 17, 2015 at 8:25:17 pm
...I can't get imported Premiere Pro sequences in AfterEffects to keyframe effects.
For instance, I have an imported PP sequence that I want to gradually blur while other AE magic is going on. Once keyframes are set from 0% blur to 100% blur and I RAM preview, the effect does nothing until it hits 100%, and it just switches on full-force. (I've tried several different effects, and they all do the same thing, so it's not just the blur effect).
I don't have this issue with regular video clips, but in this instance, I need to work with PP sequences that are edited just the way I need them.
Any insight?
Dave LaRonde
Re: Keyframing effects in AE on imported Premiere Pro sequences
on Apr 17, 2015 at 10:25:05 pm
Hounds like you've inadvertantly used hold keyframes. Highlight the keyframes, right-click on one and navigate to the "toggle hold keyframes" command. It will change them to normal keyframes.
Dave LaRonde
Promotion Producer
Dre Mark
on Apr 21, 2015 at 2:52:25 pm
Thanks Dave. The problem seems to be having the project open on Premiere and open in AfterEffects at the same time. Once I quite out of PP, I was able to work with the PP sequences in AE with no keyframe issues.
In fact, now if I have both programs open, AE freezes & won't let me work on the project until I quit out of the PP project.
