Animation with lip sync at 15 fps, client now wants video at 30 fps
Teresa Dey
on Apr 16, 2015 at 6:45:23 pm
If I just change the framerate in the composition, the exported video's lip sync is off. Is there any way to do this without having to go in and re-do the lip sync animaton?
Many thanks.
Dave LaRonde
Re: Animation with lip sync at 15 fps, client now wants video at 30 fps
on Apr 18, 2015 at 11:41:34 pm
Sorry, but you haven't provided sufficient information about the particulars of your project. If the lip sync was done by simple keyframing it should work. something else is going on.
Dave LaRonde
Promotion Producer
Tudor "Ted" Jelescu
on Apr 21, 2015 at 3:08:16 pm
Don't change the frame rate of your composition - create a 30 fps comp. Drag your original audio in. Drag your 15 fps comp in. Enable time remap on the 15fps comp layer. Extend to the expected length in 30 fps (should be double). This should create the in-between frames for you.
Tudor "Ted" Jelescu
Senior VFX Artist
