Choppy Frame Video exports & previews.
Chris Davis
on Apr 13, 2015 at 7:04:17 pm
Hi Guys, I've looked through the forums and haven't found a good solution for this problem. When rendering out a video @ 24fps it is very choppy.
Things I have tried.
1. Tried 30fps, 60fps,
2. Tried adding motion blur.
3. Tried rendering out as h.264, avi, flash, mpg.
4. Tried using 2d layers while animating position, using linear keyframes and not.
5. Tried using a camera, 3d layers, and animating the camera.
No matter what I try it looks the same. I should also mention it does this in my Ram Preview also. Thanks for your help in advance.
I will upload a video sample when it is approved by moderators.
Dave LaRonde
Re: Choppy Frame Video exports & previews.
on Apr 14, 2015 at 1:52:27 pm
Please describe the process you're using to change the frame rate. I can think of a couple.
Also, please tell us the frame rate required for delivery.
Dave LaRonde
Promotion Producer
