Alpha when exporting from AE
russell birkett
on Apr 10, 2015 at 4:57:54 pm
Hi all
I'm sure this has to be an easy fix.
I have a 3d object (ray traced renderer) with 80% transparency that looks just as I want it, ie transparent. When I remove the background colour (or footage) behind it, it appears to lose its transparency. On the trial renders I've done so far, it renders with a transparent background (which is good), but the alpha information held within the object itself is ignored and it just outputs as an opaque object.
Any help greatly appreciated
Russ
russell birkett
Re: Alpha when exporting from AE
on Apr 10, 2015 at 5:32:38 pm
I think it has something to do with the transparency settings in the material options. This gives me the look i require but doesn't export it appears.
Dave LaRonde
on Apr 10, 2015 at 9:20:00 pm
It probably has more to do with not rendering to a codec that supports alpha channels. Are you using one?
Output Module:
Quicktime Movie
PNG, Animation or ProRes 4444 codecs
Millions of Colors +
RGB + Alpha
Straight
Dave LaRonde
Promotion Producer
russell birkett
on Apr 11, 2015 at 7:36:17 am
Hi Dave
Thanks for your reply. Yep, that's exactly how I'm outputting.
'Opacity' changes are working fine, it's just the 'Transparency' under material options is only effective when it has a shape layer or footage (ie something other than transparency) behind it. As the ray-traced renderer doesn't support 'underlying transparency' I wondered if this could be the reason?
Best regards
Russ
Dave LaRonde
on Apr 11, 2015 at 9:11:30 pm
Correct. Anything else would have to be done in the next application to use the animation.
Dave LaRonde
Promotion Producer
russell birkett
on Apr 11, 2015 at 9:27:54 pm
OK, Thanks Dave
