Light Emitter Speed
Caesar Atreides
Light Emitter Speed
on Apr 9, 2015 at 4:11:35 pm
I am in the process of tracing a symbol I made in chalk. I used a null object to map the paths and then used the Null Swapper plugin to change the nulls to a lights. Now I want to duplicate the lights and speed up the speed the lights travel the path. I was trying to use the Time Remapping selection to speed up the frames but it was not available. I'm looking to speed up the lights on its path. Thank you in advance!
Dave LaRonde
Re: Light Emitter Speed
on Apr 9, 2015 at 6:05:37 pm
If you're keyframing the null along a motion path, just move the keyframes closer together. The motion will be faster.
Dave LaRonde
Promotion Producer
Caesar Atreides
on Apr 9, 2015 at 8:03:13 pm
The Null Swapper swaps the null object with active lights. I try to manipulate the position keyframes and it does not speed up the stroke rather than it thin out the light size.
