Is there a way to make several layers follow the same expression?
Tiago Cav
on Apr 8, 2015 at 8:26:25 pm
To avoid copying and pasting the same expression in the properties of thousands layers. For example, "puts expression in a null object whose "function" to act in several layers." Or any other way to help. Like Copy expression and past, without needed of open layer properties to past.
Michael Szalapski
Re: Is there a way to make several layers follow the same expression?
on Apr 8, 2015 at 8:56:33 pm
You can copy and paste the expression only. It's in the edit menu.
- The Great Szalam
Tiago Cav
on Apr 8, 2015 at 9:31:42 pm
Thank You!
I'm Ti.S.Cavalcanti. :)
