Can anyone tell me why this layers aren't showing?
David Cabestany
on Apr 6, 2015 at 6:52:05 pm
Hello everyone,
I have this comp nested into another one, neither of which is a 3D comp, no collapsed transformations or anything like that.
All the layers are showing properly inside the nested comp when the needle is parked on the in point for such layers, but on the outer comp, none if them show unless I set the in point to one frame earlier.
Can anyone tell me why?
Thanks in advance.
David.
Dave LaRonde
Re: Can anyone tell me why these layers aren't showing?
on Apr 6, 2015 at 9:44:43 pm
What's the opacity expression do?
Dave LaRonde
Promotion Producer
David Cabestany
on Apr 6, 2015 at 9:57:12 pm
It's just a master controller so I can lower the opacity as i animate the joints of the stickman. It's not animated or anything, when I render it's at 100%.
Dave LaRonde
on Apr 6, 2015 at 10:41:55 pm
Frame rate mismatch in the comps?
Any place at all where time is being altered in the comps?
Dave LaRonde
Promotion Producer
David Cabestany
on Apr 7, 2015 at 3:42:59 pm
Hey Dave, how are you? Sorry I didn't reply earlier, just saw you posted again.
You were right, thanks! i looked into the comp settings and sure enough it was set to 25 fps, when the project is 29.97, no idea how it moved to 25, maybe I clicked it by accident.
I put it back to the correct fps and now everything is working as expected.
Thanks a lot!
D.
