Fractal noise on off instead of fading
Ari Grunzeweig
on Apr 4, 2015 at 1:56:28 pm
I've created a fractal noise grid with the squares moving between black and white. Currently as the evolution is changing, the squares are fading from black to white and vice versa.
Is there a way to have them turning on and off instead of fading? As in, one frame a given square will be white (on) and then a bit later it will turn black (off) without going to shades of grey in between?
Ari
Todd Kopriva
Re: Fractal noise on off instead of fading
on Apr 4, 2015 at 3:48:09 pm
You can use effects like Posterize and Colorama to force abrupt changes in color.
https://helpx.adobe.com/after-effects/using/effect-list.html
After Effects product manager and curmudgeon
After Effects team blog
Ari Grunzeweig
on Apr 4, 2015 at 4:19:57 pm
Posterize worked perfectly! Thanks!
Ari
