Render Always Stops Halfway......
Aniruddha Gune
on Apr 4, 2015 at 1:35:55 pm
Hi,I Am A New To After Effects And Downloaded An Intro Template For It.I Edited It And Tried To Render It.When I Checked It Only Rendered 5 Seconds Of The Video. :( Can Somebody Help Me?
Any Help Would Be Appreciated. :)
Dave LaRonde
Re: nder Always Stops Halfway......
on Apr 6, 2015 at 2:53:01 pm
Sorry, but we can't. There are all sorts of templates and some are quite complicated. The people who make templates also assume the user already has knowledge of AE, ranging from basic to advanced depending on the template. Simple possession of a template does NOT guarantee success in AE.
Your best option is to follow the instructions that come with it.
Dave LaRonde
Promotion Producer
Michael Szalapski
Re: Render Always Stops Halfway......
on Apr 6, 2015 at 4:18:03 pm
If, by "rendering", you mean that you're starting a RAM preview, that just means you don't have enough RAM to preview the whole thing at full resolution. Simply change your work area and preview a different part, or lower your resolution. Alternatively, actually send it to the render queue and render out a finished product.
If, by "rendering", you actually mean that you sent it to the render queue, we will need a lot of information such as what your render settings and output module were set to, full version number of AE, what sort of error messages come up when it stops rendering, etc.
- The Great Szalam
Aniruddha Gune
on Apr 17, 2015 at 5:08:38 pm
Sorry For Late Reply
After Effects Version:9.0.3.8
No Error.....Just "Render Failed At Minute:Second"
Render Settings-------------------------------------------------------
Render Settings Are:Best
Video For Windows
Resolution Full 1280x720
Disk Cache:Read Only
Proxy Use:No
Effect:Current Settings
Solo Switches:Current Settings
Guide Layers:All Off
Color Depth:Current
Time Sampling---------------------------------------------------------
Frame Blending:On For Checked Layers
Field Render:off
Motion Blur :On For Checked Layers
Time Span:Work Are Only
Frame Rate:25(Main Comp's)
Output Module Settings------------------------------------------------
Lossless
Format:Video For Windows
Post-Render Action:None
"Checked"Include Project Link
"Checked"Include Source XMP Metadata
Video Output Settings
Channels:RGB
Depth:Millions Of Colors
Color:Premultiplied (Matted)
No Compression
Stretch:Not Checked
Crop:Not Checked
Audio Output:Not Checked
Color Management
Nothing Checked
