Animate Grain on Still Image
Brian Cheng
on Apr 3, 2015 at 10:40:19 pm
I'm going to have a still image inserted within my film. I don't want it to look like a still image, so I thought maybe adding grain would be a good idea. But when I add grain in After Effects, the grain just stays there, and does not move, which is not what I wanted. How do I make the grain move?
Palie Studios https://www.youtube.com/PalieStudios
Tudor "Ted" Jelescu
Re: Animate Grain on Still Image
on Apr 5, 2015 at 4:03:20 pm
Use Match Grain instead of adding grain and use a clip from your footage as reference. This way you'll get the same type of grain like in your footage. You will need to tweak the controls of the effect to get the best results.
Use the following as a starting point:
https://helpx.adobe.com/after-effects/using/noise-grain-effects.html
Tudor "Ted" Jelescu
Senior VFX Artist
Jim Collins
on Apr 6, 2015 at 3:17:23 am
Brian -
I've used fractal noise to animate grain in the past. It worked for showing motion in grain for some grain safety videos.
Jim Collins
