Shape Layer - Path - Gradient Stroke
mehmet savas
on Apr 1, 2015 at 7:08:27 am
Greetings from a newbie,
I'm creating a path with the pen tool and I would like this path to have the colors:
Green at the beginning
Blue towards the center
Red at the end
However gradient tool seems to work on an X-Y axis basically resulting in the attached below photo.
Basically with the attached below image: I want this line to start Green and turn Blue towards the Mid point and then Red at the End, how can I do this?
I tried a couple of keywords on google and saw a few instructions related to Illustrator but couldnt apply them to After Effects. Any keywords would also help. Thank you.
Roland R. Kahlenberg
Re: Shape Layer - Path - Gradient Stroke
on Apr 2, 2015 at 3:05:14 pm
AFAIK, you can't do that with gradients. Instead, you may use Trim Paths and multiple instances of the Path to create the your multi-colored line.
I think this effect http://www.sandervandijk.tv/blog/ouroboros may help you a lot in the process.
HTH
- Roland
TypeGEMs - the Definitive Type Gizmo for AE
http://broadcastgems.com/typegems/
Intensive mocha & AE Training in Singapore and Other Dangerous Locations
Adobe After Effects CC ACE/ACI
Imagineer Systems (mocha) Certified Instructor
http://www.broadcastgems.com/mographintensity_shapestext/
