After effects Optical flares
Andre Tran
on Apr 1, 2015 at 6:57:49 am
Im having trouble on After Effects CC trying to use optical flares. I can select them and what not but I don't see a 'red focal point' or 'control point' to manipulate and move the flare. Could someone please help me find this? Thanks in advance.
Daniel Waldron
Re: After effects Optical flares
on Apr 1, 2015 at 3:31:15 pm
To move the flare, change the center position in the Effects tab. There should also be a small circle for you to drag in your composition window. You can also attach it to a light and move it that way in 3D space.
Andre Tran
on Apr 1, 2015 at 9:26:05 pm
Thank you so much!
