Burn away effect
Richard Windsor
Burn away effect
on Mar 30, 2015 at 7:55:34 pm
I am trying to create a transition from one clip to another where the clip on top burns away very realistically. Does anyone know a good tutorial or way to do this past using the film burn with glow and roughen edges. That effect is ok but looking for something a bit more realistic.
Dave LaRonde
Re: Burn away effect
on Mar 30, 2015 at 11:05:33 pm
If you shoot the flames as a practical effect at night or in a dark studio, you get to play with combustible materials, fire and fire extinguishers.... and it looks absolutely real.
Dave LaRonde
Promotion Producer
Claude Rozsa
on Mar 31, 2015 at 5:55:29 am
You could check Video copilot for their Heat distortion plugins. And you have also this link which implies buying the effect or footage. http://www.youtube.com/watch?v=8ZOHansLZdw
Claude
John Cuevas
on Mar 31, 2015 at 2:12:50 pm
Check out this tutorial, should give you a good starting point. Creating Fire with Fractal Noise
Johnny Cuevas, Editor
Thinkck.com
"I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work."
---THOMAS EDISON on inventing the light bulb.
Richard Windsor
on Mar 31, 2015 at 5:27:49 pm
[John Cuevas] "Creating Fire with Fractal Noise"
Thanks this should help a bit.
