trouble with after effects maps and geotagging
Nicholas Natteau
on Mar 27, 2015 at 8:37:38 pm
Question for anyone who uses the After Effects "Locations" plugin to add location based data to After Effects maps. I just downloaded (and watched the tutorial) "Locations" plugin from this page:
Locations
In his tutorial, the "Locations" designer (Fabian) explains how to use gpsvisualizer's geocoder to obtain lat/log coordinates for a bunch of cities. The problem is that Google won't allow me to obtain more than one city's lat/long coordinates at a time. Google says I need an "API key" to obtain more than one city's coordinates.
I also need to know if Locations will work with any world map? Any help would be much appreciated.
Nicholas Natteau
Re: trouble with after effects maps and geotagging
on Mar 27, 2015 at 9:25:24 pm
OK no luck so far using "Locations" after downloading an equirectangular (2000 x 1000 pixel) map from wikipedi:
Basically all the cities are way way off on the world map, even though I have the correct lat/long coordinates for those cities
Tudor "Ted" Jelescu
on Mar 29, 2015 at 8:45:08 pm
Try Geo Layers- much better control and it downloads for you only the map data you need from servers.
Tudor "Ted" Jelescu
Senior VFX Artist
