Wobbly edges from keylight
Yuta Komine
on Mar 27, 2015 at 4:30:23 pm
I was wondering if there is a way to remove wobbly edges from the image below.
I tried to key this image with keylight but the edges on the shoulders and hair cannot be smoothed in any way. They become very clear when I watch the footage in 100% size in aftereffects.
[Original]
[After adding keylight]
Declan Smith
Re: Wobbly edges from keylight
on Mar 27, 2015 at 5:59:19 pm
Have you tried adding a refine matte effect with chatter enabled and altered the smoothing ? I have had good results stabilising mattes using this. Also It may be that your keying is on the edge. I would suggest using the status of key light and alter screen gain / balance to suit to ensure you have a solid key.
Declan Smith
http://www.madpanic.tv
After Effects CS6/ FCS3 / Canon XLH1 / Canon 7D / Reason / Cubase
"it's either binary or it's not"
Yuta Komine
on Mar 28, 2015 at 12:16:53 pm
Thank you very much.
Refine matte worked very well.
jerry wise
on Mar 27, 2015 at 8:17:38 pm
our keys looked like this when we were using 4-2-0 cameras and recording on xd-cam. if you blow up the raw footage to 400% and examine the transition between his coat and the background you'll probably see a mess of pixels...nothing nice and smooth.
