AE CS6 crash <0> Vid rate ratios miin, max: 1, 1
Diogo Mendes-Pinto
on Mar 25, 2015 at 12:22:47 pm
I'm trying to render a comp in AE CS6 11.0.0.378 witch among some normal effects has Element 3d 1.6.0 and Optical Flares 1.2.132 with GPU off.
Whenever I try to render I get this crash error:
Last log message was: <140735077280960> <0> Vid rate ratios min, max: 1, 1
myleniumerrors.com says: "There was an issue with the audio in your footage and it caused an encoding failure." But I don't have a single layer or file with sound in it.
Can some one help me please?
I'm on a late 2009 iMac 27' i7 2,8GHz, 8GB RAM, ATI Radeon HD 4850 512MB
Todd Kopriva
Re: AE CS6 crash <0> Vid rate ratios miin, max: 1, 1
on Mar 26, 2015 at 12:00:37 am
To begin with, install the most recent update for After Effects CS6; you are four bug-fix updates behind:
http://adobe.ly/DVA_updates
After Effects product manager and curmudgeon
After Effects team blog
Diogo Mendes-Pinto
on Mar 26, 2015 at 11:37:13 am
Thank you for your reply!
I was thinking to do that but only after I finish this project.
I managed to isolate the problem with the Element3D Layers witch I now rendered in a different comp.
By the way I pasted the error wrong. The error is : Last log message was: <140735077280960> <0> Vid rate ratios min, max: 1, 1
