After Effects Particular problems rendering
Ewan Hare
on Mar 25, 2015 at 12:15:08 pm
Hi everyone I have a slight issue while rendering out a shot in after effects.
I used trapcode particular to create fire coming out of some rockets and all looks good inside the after effects window. Unfortunately when I render the shot out I end up with black patches in my fire. Now these don't appear until I render it so I'm fairly confused as to whats happening....
Inside after effects
Rendered out
cheers
Walter Soyka
Re: After Effects Particular problems rendering
on Mar 25, 2015 at 4:15:40 pm
You're working at 1/3 resolution in your viewer; if Particular is sampling any layers, you may see a change in full-resolution output versus your reduced-resolution preview.
Alternately, you might be seeing cache errors, especially if you're on an older release of Ae or Particular. What versions of each are you running?
Walter Soyka
Ewan Hare
on Mar 25, 2015 at 5:03:45 pm
Thanks for the reply and using AEcs6 and got the newest particular (cant remember the number)
Whats the easiest way to sort this ?
Walter Soyka
on Mar 25, 2015 at 5:14:03 pm
Make sure you install the latest updates for CS6:
http://www.adobe.com/support/downloads/detail.jsp?ftpID=5697
Bump up the resolution of your viewer to Full and see if it matches your render.
Maybe clear the disk cache. Ae CS6:
Preferences > Media & Disk Cache > Empty Disk Cache
Post a screenshot of your UI showing the "shot" comp, not the render queue, so we can see what you see.
Walter Soyka
Ewan Hare
on Mar 25, 2015 at 5:40:06 pm
ok cleared the cache and check with 100% on the viewer shall stick it onto render just now and see if its fixed, cheers for the help fairly confused here ...
