Stroke Not Showing Up On Text Layers
Jacob Unterreiner
on Mar 25, 2015 at 12:40:05 am
Hey guys, I've looked on the forums for an answer but can't find anything. When I create a text layer in AE, and add a stroke to the letters it doesn't show up. It's there, as you can see the layer select box around the text is inflated where the stroke actually is, but for whatever reason it is invisible. Hopefully I'm just forgetting something really simple. I've attached a screenshot so you can see what my character settings are.
Walter Soyka
Re: Stroke Not Showing Up On Text Layers
on Mar 25, 2015 at 3:46:01 pm
Try selecting the text within the text layer (switch to the type tool, click into the layer, and select all), then adjusting the outline.
Walter Soyka
Jacob Unterreiner
on Mar 25, 2015 at 4:03:02 pm
I reset my character settings to the default by clicking Character Options(The three lines next to character in the menu)>Reset Character and it works fine now. Hopefully if anyone has the same problem that'll fix it.
