Trimming logic
Martin Mark
Trimming logic
on Mar 21, 2015 at 11:39:00 pm
I'm new to AE and I can't get a hold of it's trimming logic.
My clip is a bit too long so I trim it from the beginning and from the end with trim comp to work area.
I want to use time remapping. I enable it, but the keyframes are not going to the beginning and end on the trimmed clip, but to the beginning and end of the original clip.
How could I trim the clip so there wouldn't be anything left, but the short clip itself?
Declan Smith
Re: Trimming logic
on Mar 22, 2015 at 12:25:39 am
Trim your clip as you have been doing, then pre-compose it. You should be able to retime the precomposed clip as desired as its start / end will be as you selected on the original clip.
Declan Smith
http://www.madpanic.tv
After Effects CS6/ FCS3 / Canon XLH1 / Canon 7D / Reason / Cubase
"it's either binary or it's not"
Martin Mark
Re: Trimming logic
on Mar 22, 2015 at 9:27:19 am
Thank you, Declan!
Walter Soyka
Re: Trimming logic
on Mar 24, 2015 at 1:34:06 am
I've just published a script to enable time-remapping to trimmed layers' extents.
Presenting keen-TrimRemap:
http://www.keenlive.com/renderbreak/2015/03/keen-trimremap/
The blog post includes instructions on how to use the normal Ae shortcut for time-remapping to run this script instead, essentially making this the default time-remapping behavior in Ae. Feedback is always welcome.
Walter Soyka
