After Effects Render output as 25 fps reading as 20.91 fps in Quicktime and 20.98 fps via Avid AMA
Scott Clements
on Mar 17, 2015 at 9:45:12 pm
I have received a file from an animator that is supposed to be 25fps, but reads as 20.91 fps in Quicktime X and 7 and 20.98fps when AMA linked in Avid. It comes into Premiere and FCP as 25fps and I can successfully import the file into Avid as 25fps Avid Media. Does anyone know why it shows up as these odd frame rates in Quicktime and AMA? The main problem is that I can't edit this file into the avid project using the ama-linked media and thus the film can't be graded using the original file.
Film Editor, London UK
http://www.scottclementseditor.com
