Text tool won't work? Creates non existent text?
Josh Krauth-Harding
on Mar 14, 2015 at 3:32:21 pm
Hi, this keeps happening and I don't know why:
Not sure how to fix and it's seriously annoying. Help!
UPDATE: Now it's doing this: http://i.imgur.com/0UMS0k7.png (I'm not using the vertical text tool.
John Cuevas
Re: Text tool won't work? Creates non existent text?
on Mar 14, 2015 at 11:14:52 pm
Try decreasing your font size to something like 90 or so, then create a new text box and type in your text. Or you could press shift+cntl+alt+t to make a text layer and start typing, that doesn't have the bounding box properties that creating with the text tool has.
Johnny Cuevas, Editor
Thinkck.com
"I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work."
---THOMAS EDISON on inventing the light bulb.
Dave LaRonde
on Mar 16, 2015 at 7:11:33 pm
...and if Johnny's trick doesn't work, try setting the distance between lines of text to Auto. Currently, it's something like 320.
Dave LaRonde
Promotion Producer
Josh Krauth-Harding
on Mar 19, 2015 at 8:04:29 pm
Hi, none of the suggestions solved my problem. What would be an advised next step?
Graphic/Motion Designer in Training... lots of training.
Josh Krauth-Harding
on Mar 19, 2015 at 8:30:25 pm
Kind of an embarassing error: had the Horizontal Scale at 0%... sorry for wasting everyone's time.
