How to change groups in contents to layers itself (outlines from .ai)
Ludo Poot
on Mar 12, 2015 at 11:06:07 am
Hi all,
I am searching a way to change all the groups in the contents of my outlines layer to layers itself to animate.
1 I inported a illustrator file
2 then create outlines from vector layer
3 now there is 1 layer with all the outlines (groups) in the contents
So far so good. But now I want to animate all the created outlines (now groups).
And this is a pain in the butt when they are groups in the contents: I can't select them from the visual window (only in the contents list, I can't use shortcuts as they control the whole layer.
http://screencast.com/t/WfXeC172Ws
http://screencast.com/t/mnd3sNYXQH
I hope its understandable and somebody can help me.
Jason Jantzen
Re: How to change groups in contents to layers itself (outlines from .ai)
on Mar 13, 2015 at 2:27:31 pm
You need Explode Shape Layers 3 http://aescripts.com/explode-shape-layers/ Serioulsy handy script by Zack Lovatt.
Jason Jantzen
vimeo.com/jasonj
Wayne Graham
on May 22, 2018 at 12:07:04 pm
As an update to this, you can now use overlord to command shape layers between illustrator with a lot more ease and control.
This script has changed my life, highly recommended !
THANKS !!!
