Touching Twitch Makes After Effects Not Respond
Eric Tong
on Mar 11, 2015 at 1:14:34 am
Every time I do something to the twitch plugin (add to comp, change value, edit length of layer with twitch) after effects stops responding for a really long time (5 min). This doesn't happen with any other plugins. I tried reinstalling twitch 3 times already. Anyone else had this problem?
Daniel Waldron
Re: Touching Twitch Makes After Effects Not Respond
on Mar 11, 2015 at 4:04:25 pm
Never had that issue. Did it used to work normally for you? If so, the issue can usually be tracked back to a change in your system or software.
You could also email VideoCopilot. They're usually pretty responsive.
Eric Tong
on Mar 11, 2015 at 9:48:35 pm
Good point, I never did have that issue before. Thanks, I'll try emailing Video Copilot, but I don't really know how to trace this problem...
