Breaking Snowball effect in fter Effects?
James Dunne
on Mar 5, 2015 at 1:26:55 pm
Im looking to create an animation of a snowball been thrown at a wall where it breaks apart on contact or been thrown directly into the camera. Can I make this in after effects?
Similar to this video but more realistic :
John Cuevas
Re: Breaking Snowball effect in fter Effects?
on Mar 5, 2015 at 2:36:05 pm
You would want to use a particle emitter/system. Probably 1 layer would be the snowball, and as it hits the lens, it explodes into particles. Trapcode Particular or the CC Particle systems probably could create the explosion. You might also experiment with the Simulation > Shatter effect to create this type of effect.
Johnny Cuevas, Editor
Thinkck.com
"I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work."
---THOMAS EDISON on inventing the light bulb.
